MAQUET - Venta SP 26
by MAQUET
Bronchial Aspirator
The high-performance MEDAP VENTA SP 26 has a high flow rate, enabling it to draw blood, septic fluid, vomit, and serous fluids quietly from both natural and artificial body orifices. This feature makes it ideal for nasal and oral bronchial aspiration applications and for endoscopy. Specially developed for universal, continuous use on wards, the portable bronchial aspirators are perfect for use in hospitals, clinics, and medical practices or in military medical services.
7RepliesThu Mar 13 2025 | service manual or circit diagram hi Guys, in our cardiac ICU, we have 7 suction machines, and we have the same problem. When the machine is turned on, the push button comes blue, it makes a sound like there is no power, when I check the outlet for 12v for the motor, it is not present. if somebody has experience with this kind of problem, please, if you can help me THANK YOU Equipment: medap vent sp 26 Reply |
Time Saving
due to the special recessed grip in the vacuum controller, which indicates the set vacuum at all times
Quiet
thanks to the specially developed piston motor
Safe
thanks to a special mechanism that makes oversuction of the aspirator impossible
| Weight | 3.7 kg 11.4 kg with trolley |
| Vacuum Range | 0-622.3 mmHg (0-24.5 inHg) |
Vacuum Setting
Oversuction prevention
