Olympus - KV-6
by Olympus
Suction Pump
The KV-6 Suction Pump is designed for endoscopic aspiration. The unique flow change buttons allow a fast vacuum build-up with a single touch. It has a 'whisper mode’ for quiet operation and ‘turbo mode’ for faster suction.
High Suction Performance The KV-6 suction pump has vacuum capabilities of up to -95kPa. There are three pre-set speed settings (40l/min, 50l/min and 60l/min), which enables the operator the flexibility to control the rate of vacuum build-up at a touch of a button.
Cleaning and hygiene  Single use collection system allows easy and safe disposal of clinical waste. Touch sensitive buttons do not protrude making external cleaning easier.
Compatibility Compatible with existing KV-5 accessories and Olympus workstations.
Height22 cm
Length 31 cm
Weight12.7 kg
Width25.5 cm
