Richard-Allan Scientific - Microm HM525 NX
A high performance routine cryostat with intuitive software and touchscreen for simple, efficient operation.
The Thermo Scientific HM525 NX Cryostat combines the proven operation and reliability of the HM525 cryostat and the new ergonomics and intuitive interface of the Thermo Scientific NX series cryostats. The result is cryostat that allows users to deliver high quality routine results comfortably and efficiently.
FORUMSView All (8)
0Replies6 months ago | Cryostat HM525 - ERROR 005-001 Microm HM525 displays a communication error with C-Touch(005-001). Does anybody knows what happened and how to fix it? Reply |
4Replies9 months ago | TEMPERATURE PROBE I need a temperature probe for Microm HM520 or HM525 ( part number 330320). The probe is not available from the thermo fisher scientific. Does anybody know the datasheet for this probe, so I can find a compatible one or have it remanufactured? Reply |
2Replies4 years ago | Microm HM525 NX cooling issue? Microm HM525 NX The microtome base gets colder than the evaporator coil. This is especially a problem since there appears to be no way to shut off the daily defrost (which only defrosts the evap coil); having the microtome base that cold means that the ice builds up on the microtome base. I know there are cooling coils under the base of the microtome, but I'm not sure what the configuration is, or how those coils relate to the coils in the evaporator. Has anyone seen this issue? What did you find?Reply |
- Chamber cooling to -35°C
- 27 cryobar storage positions including 4 quick freeze locations
- Integrated peltier fast freezing device rapidly cools to -57°C±3°C
- Programmable and immediate defrost options
- Manual light touch rotary flywheel
- Section thickness from 1µm to 500µm
- Memory function for rapid advance and specimen positioning
- Vertical stroke length of 60mm
- 28mm horizontal feed range
- 40++m specimen retraction on return stroke
- XY specimen orientation with 360° z axis rotation
Height | 47.4 in |
Length | 30 in |
Weight | 275 lbs |
Width | 25 in |
