GE HealthCare - Tec 6 plus
by GE HealthCare
Desflurane Vaporizer
The Tec 6 Plus is an electronic vaporizer that heats Desflurane to maintain constant temperature and vapor pressure for consistent output. Tec 6 Plus incorporates an LED display indicating vaporizer status: no output, low agent, warm-up, operational, and alarm battery low.
  • Features several intrinsic vaporizer monitoring functions and alarms that constantly monitor vaporizer status
  • Incorporates a self-test system that checks a range of conditions each time the unit is turned on
  • Includes an LED display with low agent level alarm
Large Capacity and Easy Refilling
  • The Tec 6 Plus has a large, 425 mL sump capacity to accommodate nearly two full bottles of Desflurane, letting you use the vaporizer for extended periods before refilling.
  • Refilling can be done while the vaporizer is in use.
  • The exclusive Saf-T-Fill valve of the Desflurane bottle is designed to fit only the complementary filling device of the Tec 6 Plus, so you can refill quickly. This valve helps prevent accidental release of vapor into the OR and helps to ensure that only Desflurane is introduced into the Tec 6 Plus.
