ALVO Medical - Serenada-C
by ALVO Medical
Operating Table
The new generation angiography operating table ALVO SERENADA-C is designed to hold the patient during surgical and diagnostic procedures and medical imaging. Tabletop translucency is max. 0,35 mm Al eq per 10 mm of tabletop thickness. Long tabletop provides 1,7 m of X-ray area making it one of the longest tabletops in its class
Tabletop length | 2500 mm | Table weight | ~ 370 kg |
Tabletop width | 600 mm | Max. dynamic load capacity | 220 kg |
Tabletop width (with side rails) | 650 mm | Power supply | 24 V |
Height adjustment (without pads) – floating tabletop | 740 – 1190 mm | Battery charging time | < 12 h |
Lateral tilt adjustment | 25o / -25o | Working time between battery charging | approx. 60 operations |
Longitudinal shift (if featured) | 500 mm | Battery charger | Built-in |
Lateral shift (if featured) | 400 mm | Charging current | 230 V ~50/60 Hz |
Trendelenburg reverse -Trendelenburg | 30 o 30 o | International Protection Marking | IP-X4 |
