ALVO Medical - Rapsodia
by ALVO Medical
Operating Table
ALVO Rapsodia provides an exceptional height adjustment range of 610 – 1240 mm (without pads), which combined with a longitudinal shift of 420 mm, makes it the perfect fit for any desired working level.
The best-in-class max. load capacity of 320 kg at any articulation allows for use in a variety of surgical disciplines, including bariatric surgery.
The ALVO Rapsodia is compatible with the full portfolio of ALVO accessories line to adjust to almost any surgical position.
Remote Control Functions:
Height, leg support, Trendelenburg, Reverse Trendelenburg, Lateral Tilt, Longitudinal Shift, Back Section, Leg Support, Tabletop Leveling, Flex Position, Reflex Position, Brake
Tabletop length
Modular
5 section
2110 mm (2125 mm*)
2115 mm
    Trendelenburg
reverse-Trendelenburg
 40o
40o
Tabletop width500 mmLongitudinal shift420 mm
Tabletop width (with side rails)560 mmTable weight300 kg
Height adjustment (without pads)610 – 1240 mmMax. dynamic load capacity**275 kg
Back rest adjustment80 o / -30oMax. static load capacity (over base)320 kg
Foot rest adjustment20o / -90oPower supply24 V
Foot rest abduction180oBattery charging time< 12 h
Lateral tilt adjustment30 o / -30oWorking time between battery chargingapprox. 60 operations
Head rest adjustment45o / -45oBattery chargerBuilt-in
Foot rest motorized adjustment (option)80°/-90°Charging current230 V ~50/60 Hz
Kidney bench elevation (option)150 mmInternational Protection MarkingIP-X4
