ALVO Medical - Serenada-B
by ALVO Medical
Operating Table
ALVO Serenada-B is an electro-hydraulic, mobile operating table made of stainless, acid proof steel. The table can be equipped with wide range of table tops and bases. Functional movements of the table column are provided by reliable electro-hydraulic system. Movements of the back section and kidney bench are performed electro-hydraulically, leg rest and footrest are supported on the gas springs. Longitudinal shift is equipped with mechanical brake. Multisectional table top allows to reverse the orientation of the sections. ALVO Serenada-B offers also modular table top with short back section for better access to the shoulder area.
Perfect for the following Disciplines:
  • Bariatric Surgery (BS)
  • Cardiovascular (CV)
  • Colorectal Surgery (CRS)
  • General Surgery (GS)
  • Gynecology (GYN)
  • Minimally Invasive Surgery (MIS)
  • Neurosurgery (NS)
  • Ophthalmology (OPHT)
  • Orthopedic and Traumatology (OT)
  • Otorhinolaryngology (ENT)
  • Spinal Surgery (SS)
  • Urology (UROL)
Tabletop length
Modular
4, 5 sections
2110 mm (2125 mm*)
2115 mm
Longitudinal shift300 mm
420 mm (option – motorized shif)
Tabletop width500 mmTrendelenburg
reverse -Trendelenburg
40 o
40 o
Tabletop width (with side rails)560 mmTable weight250 kg
Height adjustment (without pads) – mobile base, manual longitudinal shift670 – 1120 mmMax. dynamic load capacity**275 kg
Height adjustment (without pads) – mobile base, POWERED longitudinal shift680 – 1130 mmMax. static load capacity (over base)320 kg
Back rest adjustment75 o / -35 oMax. patient weight450 kg***
Foot rest adjustment20o / -90oPower supply24 V
Foot rest abduction180 oBattery charging time< 12 h
Lateral tilt adjustment30o / -30oWorking time between battery chargingapprox. 60 operations
Head rest adjustment45o / -45oBattery chargerBuilt-in
Foot rest motorized adjustment (option)80°/-90°Charging current230 V ~50/60 Hz
Kidney bench elevation (option)150 mmInternational Protection MarkingIP-X4
