UMG/Del Medical - OTC18S
by UMG/Del Medical
Overhead Tube Crane System
Versatile and intuitive, the OTC18S system delivers automated stitching, from a wall stand or table, enabled by sophisticated motorization and software, at an economical price point. Workflow is also optimized for all exams thanks to vertical and horizontal tracking functionality. Precisely designed to withstand high-volume throughput in hospital radiology departments, medical imaging centers, and large orthopedic facilities with the need to perform a broad range of radiographic studies.
Features a large Led touchscreen interface enabling the technologist to view adjust and control most system settings.
| ROOM HEIGHT | 105 – 119 in (267 – 302 cm) |
| ROOM HEIGHT (WITH OPTIONAL TELESCOPIC EXTENSION) | 105 – 127 in (267 – 322 cm) |
| VERTICAL TELESCOPIC TRAVEL RANGE | 70.8 in (180 cm) with minimum 32.7 in (83 cm) focal spot to ceiling distance / 15.5 in (39.4 cm) focal spot to floor distance with a 9 ft ceiling height |
| LONGITUDINAL TRAVEL RANGE | Standard: 14 ft rail included, 136 in (346 cm) min Optional: rail extensions: 220 in (558.5 cm) max |
| TRANSVERSE TRAVEL RANGE | Standard: 10 ft (3 m) track / 86.6 (220 cm) Optional: 13 ft (4 m) track / 140 in (355 cm) |
| LONGITUDINAL DETENT POSITIONS | Configurable during installation |
| TUBE ROTATION RANGE (HORIZONTAL AXIS) | -120°, +120°, Detent positions at -90°, 0°, +90° |
| TUBE ROTATION RANGE (VERTICAL AXIS) | -182°, +154°, Detent positions at -180°, -90°, 0°, +90° |
| LOCKS | All Lock release sensor on bottom handle to release transverse, longitudinal, and vertical locks Individual membrane lock releases – Roll Lock – Column Rotate – Up – Down – Longitudinal – Transverse – Vertical – Vertical/ Longitudinal / Transverse |
| WEIGHT (WITH COLLIMATOR AND TUBE) | 507 lbs (230 kg) |
| POWER REQUIREMENTS | 24 VDC 8A (Supplied by the DM-PSI) |
