CT Scanner
VetCAT IQ is a compact, mobile CT scanner designed for use in Veterinary Clinics of all sizes. VetCAT IQ rolls easily into position at your patient’s table. With the push of a button, you get a high-quality CT scan of your patient in less than a minute.
VetCAT was specifically designed for bone imaging capability—meaning it is ideally suited for dental and dermatology imaging.
Clinicians who are wanting to see brain, eye, and other tissue anatomy of the head and small animal turn to the VetCAT IQ.
VetCAT IQ equips you with state-of-the-art Computed Tomography (CT) scanning at your fingertips.
With its compact size and zero-turn capability, VetCAT IQ clears standard doorways, accommodates tight spaces, and is easy to access when you need it and store it away when you don’t. To use VetCAT, you simply roll the scanner up to your patient’s table, follow a few simple steps, and you get 20 second ultra-low radiation dose CT. Your scan will appear on the built-in monitor, where you can examine your region of interest in a 3D volume rendering or by 3D cross-section.
