Siemens Healthineers - Cios Flow
by Siemens Healthineers
Mobile C-Arm
A good workflow is half the job, since interruptions can negatively impact both patient safety and OR efficiency.1 And other, invisible disruptions are on the rise: cyber attackers are taking advantage of security gaps to access patient data and compromise vulnerable healthcare systems.2
This new mobile C-arm can help you to make your procedure more straightforward and efficient. It assists you in your daily routine while also supporting multidisciplinary utilization.
-Michael O
Mon Dec 08 2025
Knob broken- unable to disconnect carm connector
Hello- we have a carm with a broken knob so we cannot disconnect the carm. Is that a trick to removing it without damage since it works as is but cannot be disconnected?
Thanks!
Equipment: Siemens Healthineers - Cios Flow
-ceshop
Sat Apr 27 2024
Service manuals
Does anyone have the manuals for the CIOS Flow?
Thank you
  • Designed for more ease in the OR
  • Versatility supports system utilization
  • Cyber security to safeguard data and access
  • Retina Imaging Chain with CMOS technology: Intelligent algorithms automatically adjust brightness and contrast, detect motion, enhance edges, and optimize metal visualization for improved depiction of surrounding tissue.
  •  SpotAdapt and touch gestures: SpotAdapt automatically optimizes imaging parameters to the anatomy of interest. Tablet-like touch gestures let you collimate, rotate, and flip images – and take advantage of SpotAdapt – with just one finger.
  • High-brightness green lasers: For improved visibility on all skin types and blood – despite bright OR lighting.
  • Lightweight system design: Featuring a non-compromising C-design, and weighing only 606 lb (275 kg), Cios Flow is particularly easy to position and move.
  • Wireless footswitch: For less hassle around the equipment and more freedom in the OR.
CARE program (Combined Applications to Reduce Exposure): Yes
Angi-microbial coating on C-arm and housing: Yes
Data transfer: LAN / WLAN* / USB / DVD
Image storage: 300,000 images
