Siemens Healthineers - Biograph Vision Quadra
by Siemens Healthineers
PET/CT Scanner
The power of a proven platform. The perspective of a large axial PET field of view. Biograph Vision Quadra™ takes the potential of PET/CT even further. Dynamically see vertex to thighs in a single position and deepen the dimension of your investigations. Whether you’re exploring new research questions or identifying the best clinical approach, with Biograph Vision Quadra, the answers are yours to find.
Engineered for new research dimensions: With 106 cm axial PET field of view, Biograph Vision Quadra offers a whole-body (vertex to thighs) perspective so you can scan more in one position to dynamically follow tracer kinetics throughout the body. And with best-in-class time-of-flight performance and PET effective sensitivity1, you can see with outstanding clarity. From tumor perfusion over time, to diverse physiological processes, to pediatric imaging and more, Biograph Vision Quadra exponentially expands your realm of investigation.
Developed to reshape clinical outcomes: The accuracy, performance, and reproducibility of Biograph Vision are the gold standard in PET/CT imaging. With Biograph Vision Quadra, you achieve the same outstanding detail and definition that you have come to expect—increased detectability of smaller lesions, reduced scan time and effective dose, and faster evaluation of treatment impact2. And now with higher effective sensitivity gained from a 106 cm axial PET field of view and the best time of flight1, no matter your imaging application, Biograph Vision Quadra delivers proven clinical outcomes at a greater scale.
Designed for your realities: When envisioning the first whole-body PET/CT scanner, a key consideration was designing a system that fits into your existing environment. With a 106 cm axial PET field of view, you can perform a whole-body scan in one position on a machine built for the same space as a traditional PET/CT scanner. Our innovative architecture is designed for easy serviceability, efficient data management, and enhanced workflows. With Biograph Vision Quadra, you have research and clinical solution designed for your realities.
