Biological Irradiator
The powerful Rad Source RS 1800·Q X-ray Irradiators are designed to investigate biological responses while providing maximum research versatility accommodating cell, tissue culture, seeds and many more life science applications.
High X-Ray Output – High Throughput
- Produces a high x-ray output, and has a large field, providing advantageous configurations for high throughput and dose rate.
Better Uniformity
- Due to the larger field with no need to collimate the beam, a better uniformity can be achieved compared to standard imaging tube x-ray technology.
Beam Hardness – Built-in Filtration
- Quastar has filtration built into the design of the x-ray emitter – designed to attenuate weaker non-penetrating x-rays.
Power Efficiency – Increased Life Span
- The Quastar emitter runs at less than maximum power which increases lifetime of 7 years or more – up to 2.5X longer than the standard imaging x-ray tube x-ray.
Repairable Energy Source Design – Manageable Cost of Ownership
- Unlike traditional imaging x-ray sources that require full replacement, the Quastar emitter is engineered to be repairable and last up to 7 years. Only Quastar can achieve superior dose uniformity resulting in lower run times.
- No Radioactive Source – Lower Cost of Ownership (RS 1800)
- Meets safety requirements specified in Fed. Reg. 21 CFR 1020.40.
- No Nuclear Regulatory Commission (NRC) License is required.
- No nuclear disposal requirements.
- No additional security requirements for nuclear equipment.
- No additional safety equipment for laboratory staff.
- Direct Replacement for Gamma Irradiator
- U.S. Government recognized as a safe and direct alternative for radioactive isotope (gamma) source irradiators.
RS 1800·Q One Day Plug & Play Installation
- The RS 1800·Q does not need an external water connection to the facility – providing improved workflow efficiency with flexible equipment placement throughout the facility.
Instrument Portability
- Mounted on sturdy caster wheels for convenient portability improves sample workflow efficiency, allowing for the placement of the RS 1800·Q throughout the facility.
Self-Contained Cabinet
- All Rad Source irradiators are manufactured as cabinet x-ray devices and conform to the radiation safety guidelines in US CFR 21 1020.41.
| Height | 162.56 cm |
| Weight | 1350 |
| Width | 76.2 cm |
