Animal Irradiator
RadSource's proprietary biological irradiators are validated and widely used to configure the immune systems of laboratory animals so they can be used in both cancer research and research on the immune system.
Multi-level Chamber Exposure System
- The exposure chamber incorporates a five level manually adjusting tray for flexible specimen placement.
- Concentric circles on the aluminum shelf correspond to the size of the radiation field at a corresponding height.
- Irradiating small animals in their cages reduces cross-contamination and provides a less stressful therapy environment.
Exposure Chamber Guides
- (5) height levels for tray positioning (1 to 5)
- (6) Circles guides for sample placement of specimen target.
- No radioactive source – No ongoing regulatory hassles
- Direct Replacement for Nuclear Source Irradiators
- Considered “substantially equivalent” to Cesium-137 gamma irradiators.
- Meets all safety requirements specified in Fed. Reg. 21 CFR 1020.40.
- No Nuclear Regulatory Commission (NRC) License is required.
- No nuclear disposal requirements.
- No additional security requirements for nuclear equipment.
- No additional safety equipment for laboratory staff.
Onboard Cooling System
- No external water source/connection or drain hook-up is needed – allows for convenient facilities placement of instruments for increase workflow efficiency.
Instrument Portability
- Mounted on sturdy castor wheels for convenient portability for flexible placement improving sample workflow efficiency.
