OrthoScan - TAU 1512
by OrthoScan
Mini C-Arm
Designed around your needs, Orthoscan TAU 1512 introduces the next generation of mini C-arms.
Exclusive dose-saving features, advanced Orthotouch interface, and improved articulation and arm design are all packaged in a small and light-weight form factor you expect from an Orthoscan mini C-arm.
0RepliesTue May 26 2026 | service manuel looking for PM manual Equipment: orthoscan tau 1512 Reply |
2RepliesFri May 02 2025 | Brake handle assembly replacement How do you remove the brake handle assembly from the mini c arm Reply |
Free space: 13.8″
Weight: 475lb
Height: 48”
Footprint (W x L x H): 29x33x48”
Orbital rotation (over rotation): 160°
Pivot rotation: 430°
Lateral rotation (wig-wag): 320°
Vertical range: 26.5”
Arc depth: 20”
Distance to cabinet: 58”
Distance to wheel base: 44”
Keyboard handles: Yes
Type: CMOS detector
Detector resolution: 2.0 k x 1.5 k
Field of view (full): 14cm x 10.9cm
Field of view (collimated): 10.9cm x 8.4cm
Detector size: 15cm x 12cm
Useful array: 15cm x 12cm
Pixel spacing: 75 microns
Dose rate: AKR / DAP
