OrthoScan - TAU 1515
by OrthoScan
Mini C-Arm
For those who desire more, TAU 1515 delivers the innovative features you expect from an Orthoscan mini C-arm.
A larger detector and live image give you the freedom to view anatomy as it needs to be seen. Pulsed fluoroscopy and other dose-saving features reduce your dose without sacrificing image quality. Pediatric indication – an industry first – broadens your patient base.
6RepliesWed Jun 05 2024 | Need to know why I can not XRay System boots fine however when you try to X-ray from the foot pedal or from the system it self it will not X-ray Reply |
2RepliesTue Sep 19 2023 | Password Needed I am in need of the password in order to change Network Setting and to perform a Back Up. I can be reach @ 347-703-7585 or napoleon.elliott@crothall.com.. Reply |
Next generation CMOS detector
Advanced user interface Orthotouch™ 2.0
Improved bilateral controls
Large flat-panel detector: 15 cm x 15 cm
24" high-resolution LCD monitor
Increased orbital rotation of 160°
Pulsed fluoroscopy
Optimized dose filter
Approved for pediatric use
Anatomical selections via Orthotouch™ 2.0
Surgical LED lights
Enhanced data security
Easy access to buttons and ports
Free space: 13.8″
Weight: 475lb
Height: 48”
Footprint (W x L x H): 29x33x48”
Orbital rotation (over rotation): 160°
Pivot rotation: 430°
Lateral rotation (wig-wag): 320°
Vertical range: 26.5”
Arc depth: 20”
Distance to cabinet: 58”
Distance to wheel base: 44”
Keyboard handles: Yes
