GE HealthCare - LightSpeed VCT Select
by GE HealthCare
The Ultimate Multi-Slice CT!
LightSpeed VCT Select delivers the ultimate performance in multi-slice CT technology, bringing significant enhancements to that offered by previous multi-slice CT. Acquisition times are significantly reduced: static organs can be imaged in two seconds, a whole body scan can be completed in a breathhold, and the heart can be scanned in 10-12 seconds! Clinical performance is considerably enhanced in cardiovascular, perfusion, lung, trauma, and pediatric studies.
HiLight™ Matrix III Detector - Enables true 32-slice imaging in two modes: 32 x 0.625 mm with 20 mm coverage or 32 x 1.25 mm with 40 mm coverage. Get resolution and speed when you need it! With Volara™ Data Acquisition System (DAS) reducing significantly electronical noise, LightSpeed VCT Select provides optimal image quality, even at low dose. Acquire 17.5 cm in a second! Image the complete body in just 10 seconds by using the full width of the 40 mm detector and the highest acquisition speeds. Performix™ Pro Tube: The power to sustain image quality for every patient... at the fastest rotation speeds with the most powerful Xray source: 100 kW, 800 mA at 120 kV! Xtream™ FX Get into the Volume at the speed of up to 16 fps*. Don't down sample, don't work in 2D! Go directly to true 3D volumetric data with the right advanced application!
Type (configuration)Multislice
Slices32
