Enternal Feeding Pump
The Kangaroo™ Connect Enteral Feeding System is the first enteral feeding pump with wireless connectivity and is for use from the hospital to the home.
- Magnetic feeding set identification system to ensure a match between the pump’s user interface and feeding set type
- State of the art STOP (Safety Threshold Overflow Protection) valve automatically prevent free flow conditions, even when feeding set is unloaded from the pump
- Audible alarm to indicate errors or feeding set loading conditions
- Pump orientation-independent design eliminates need for drip chamber on feeding set
- Sensor technology detects both upstream and downstream flow conditions
- Continous feed and dose feed capability
- Auto-prime feature reduces the need for time-consuming namual priming
- Extended hold option
- View previous 72 hours of feeding history
- 17 languages
- ~24 hour battery l;ife at 125 mL/hr (using Power Save and Airplane Mode)
- Unique wireless technology allows for:
- Remote troubleshooting for user support
- Future software upgrades and new features
- Long term historical trending to better meet patient needs
- Quiet pump operation
- Compact, lightweight design
- Tabeltop, bed rail or IV pole mounting
- Simple, one-handed loading of pump cassette
- Pump is designed for cleaning under running water
- Rubberized casing for better grip
- Pole clamp can detach from pump without removing from IV pol
