Covidien - SonarMed
by Covidien
Airway Monitoring System
Precious neonatal patients require precise endotracheal tube (ETT) monitoring. The SonarMed™ airway monitoring system is the only ETT airway monitor to provide real-time visualizations at the bedside for accurate, informed troubleshooting, which may save precious time and help reduce unplanned extubations.†
SERVICE COMPANIESView All Medical Monitor Companies
Help Reduce Unplanned Extubations
  • During mechanical ventilation in the NICU, unplanned extubations are the most common adverse events impacting nearly 1 in 5 patients
Decrease Costs, Reduce LOS
  • One study found that each unplanned extubation in pediatric patients leads to hospital costs of $36,692 and an increase of more than six days per case.
Improve Quality Measures
  • Use of SonarMed™ technology may also lower unplanned extubations when combined with other quality measures.
  • Assists in detecting ETT tip movement and direction both upward and downward, notifying clinicians of potential ETT migration in real time.
  • Bedside monitor displays the percentage and location of any obstruction within the ETT and can indicate if removal efforts were successful.
  • Measures the circumference of the patient’s trachea at the tip of the ETT to observe any migration toward a smaller or larger passageway.
  • Easy-to-read screen displays any status changes of the ETT, and monitors the correction of the tube to the optimal baseline position.
  • Customize alarms to sound when migration or obstruction is detected.
