Getinge - Servo-Air
by Getinge
Ventilator
Servo-air is a wall-gas-independent mechanical ventilator for adult and pediatric patients that moves easily with you throughout the hospital.
As a turbine-driven ventilator with powerful battery backup, it can be used for both non-invasive and invasive ventilation on the go. Easy to learn and use, Servo-air gives you affordable access to High Flow therapy, Servo Compass, CO2 monitoring and other key personalized ventilation tools available on our advanced models.
Context-based guidance
  • Servo-air provides informative guidance for everything from pre-use check to initial parameter setting and throughout the entire treatment.
Safety Scale parameters
  • The system Safety Scale tool makes parameter changes quick and intuitive, while dynamic images illustrate how those changes may affect ventilation.
Choose your view
  • Basic, Advanced and Loops
  • Distance and Family
  • Servo Compass
Alarm management
  • The frame lights up when an alarm is triggered, and this visual signal is easy to see from any viewpoint. On-screen checklists help you to manage each active alarm and avoid undesired alarms.
Fast and reliable CO2 monitoring
  • To measure carbon dioxide levels in real time during expiration (capnography), Servo-air comes with an easy-to-use CO2 monitoring option. It helps you to improve the ventilation quality and efficiency for your patients. In other words, yet another tool on Servo-air to help you personalize your treatments.
Interchangeable expiratory cassette
  • Servo-air features a one-piece cleanable expiratory cassette, so the system can be ready for the next patient almost instantly. These can be used for both invasive and non-invasive ventilation.
Similar serviceability across ventilation fleet
  • The Servo-air and the advanced Servo-u® have similar user-friendly interfaces. They also share many components, have the same interchangeable patient cassettes, and come with the same easy-access service structure.
