Getinge - ED-Flow
by Getinge
Endoscope reprocessor
The Getinge ED-Flow AER is a true barrier system, meant to separate the dirty and the clean endoscope reprocessing areas as a physical barrier.
Getinge ED-FLOW AER is the perfect solution for large endoscopy departments, thanks to two separate chambers and short cycles which offer excellent capacity to reprocess two endoscopes at the same time in a fast, efficient 23 minute cycle.
Interlocked doors ensure that only scopes that have run through a complete and approved cycle can be unloaded from the clean side. If an error occurs during the process, the AER will only open on the dirty side.
User- friendly interface and hands-free operation
Independent asynchronous chambers
Physical barrier
Fast cycles and high capacity - up to 6 endoscopes per hour
Automatic process documentation for traceability
Easy, safe and secure chemicals handling
| Height | 75.1 in |
| Width | 43.3 in |
