Steam Sterilizers
Biocontainment suites have unique needs for maintaining the integrity of the containment area to protect the research, staff, and outside environment. Because of the pathogenic nature of material handled in BSL-3 and BSL-4 facilities, sterilizers are used as a barrier between containment areas. GEB Steam Sterilizers are engineered specifically for supporting these unique workflows. They work with biocontainment facility design and processes to ensure the safe and efficient handling of biohazardous materials.
Effective effluent treatment
- Containment presents several challenges on sterilization system design.
- With GEB Steam Sterilizers, air is initially evacuated from the secure chamber through a sterile membrane filter. The filter is sterilized together with the load during a sterilization process; an optional second filter can be installed for added security. Condensate is collected and deactivated during sterilization.
- Optional automatic in-line water intrusion testing (WIT) ensures the integrity of the filter system.
Reliable process control
- When handling toxic and pathogenic waste material in life science applications, decontamination process control and reliability is crucial. The control systems accurately handle tasks such as parameter setting, recipe handling, sequence control, data processing, batch reporting, and storage. The sterilizers are controlled using an intuitive HMI touchscreen panel; operators may select the appropriate process and adjust parameters (Supervisor restricted). During the process, the operator receives clear feedback of process status, alarms, and process time remaining — all clearly visible from a distance.
