BC Group - IPA-3400
by BC Group
Infusion Pump Analyzer
The IPA-3400 is the most compact, full featured four channel analyzer on the market.
It is a high accuracy, easy to use system that incorporates full touch screen control of all processes without the use of old fashioned buttons and knobs. This new cutting edge, Patented design uses a dual syringe stepper motor driven system that provides continuous monitoring of the fluid flow without the need to stop and perform intermittent drains like older technologies do. This provides a more realistic flow path for the Infusion Device under test and therefore more accurate readings. Also, independent stepper motor control of the custom designed ceramic valving allows the system to run not only more quietly and more smoothly, but it also allows for a bidirectional powered fluid flow for use in the built-in cleaning cycle
Smaller in Size - Larger in Features
• Faster in Operation
• Easier To Use
• High Accuracy
• Large 7” Color Touch Screen
• 1,2,3 and 4 Channel Models Available (Field Upgradeable)
• User Swappable Fully Self Contained Flow Modules
• Calibration in Flow Modules
• No Need To be Down For Calibration or Service
• Smooth Dual Syringe System
• Eliminates Drain Cycle Inconsistencies
• Whisper Quiet Operation
• Auto Start
• Built in Auto Test Sequences
• Built in Data Collection
• Industrial Grade SS Pressure Sensor
• Performs All IEC 60601-2-24 Required Tests
• 0.1 mL to 1600 mL/Hr
• 4 USB Ports & 4 AUX Ports
• Flash Drives, Barcode Scanners, Keyboard and Mouse Directly Supported
• PC Compatible
• Configurable Pressure (mmHg, PSI, Bar, kPa)
• Large 32GB Internal Memory
• US Patent No. 10,100,828
