Abbott - Omni-Flow 4000 plus
by Abbott
Infusion Pump
The Omni-Flow 4000 Plus can improve overall nursing and clinical efficiency in a portable, versatile and dependable multi-channel device. Concurrent flow with positive controls manages multiple medications freeing time spent setting up multiple single line systems.
The Omni-Flow 4000 Plus is a sophisticated device that precisely manages high-demand infusion requirements. Consolidated delivery of up to four medications and one patient access site can help improve patient safety, nursing workflow and clinical precision
 With the Omni-Flow 4000 Plus, nurses may spend less time managing I.V. infusions and more time managing patient care. The single patient access line can also reduce administration sets, patient room clutter and overall drug delivery costs. Its ease of operation helps shorten clinical staff learning curves and may contribute to increased proficiency.
  • Four-channel medication delivery through a single patient line
  • Programmable
  • Multi-dose containers
  • Programmable automatic in-line dilution
  • Programmable automatic flushing between incompatible medications
  • Any combination of both continuous and intermittent infusions
  • Real-time clock
  • Pumping Mechanism Piston Diaphragm
  • Dimensions 11.25 H x 12 W x 7.5 D inches
  • Weight Approximately 14.5 lbs
  • Casing High density polyurethane structural foam
  • Power Requirements 120 VAC, 50/60 Hz, 50 W
  • Fuses Slo Blo, 0.6 A, 250 VAC
  • AC Line Leakage Less than 20 microamperes
  • Power Cord Plug Hospital grade (3 pin)
  • Battery 12 volt, sealed lead acid, rechargeable
  • Battery Life Approximately five hours of operation at 125 mL/hr
  • Battery Recharge Time 24 hours with device OFF
  • Nurse Call Jack 2.0 A, 30 VDC maximum.
  • Standard 1/4 inch phone jack with normally open isolated contacts
  • Communications RS-232, DB-9 connector set to 9600 baud
  • Delivery Rate Ranges
  •  - 1.0 mL to 100 mL per hour in 0.1 mL/hr increments up to 100 mL;
  •  - 1.0 mL/hr increments from 100 to 700 mL/hr
