Cardinal Health - Alaris GH
Syringe Pump
The Alaris® GH syringe pump is intelligent and highly responsive and delivers drugs in the safest possible way.
It has a large easy to read display, intuitive keyboard, alarm beacon and on-screen drug labelling.
It can be used with the Guardrails® Suite of safety software providing the power to identify, track and prevent many of the harmful IV medication errors.
- Simple to use and operate
- Large graphics format display
- Medical Device Interface (MDI): a unique mounting mechanism
- Event logging records operation of pump
- Advanced communications and nurse call interfaces
- Configurable drug names
- Syringe size/type: 5, 10, 20, 30 or 50 ml disposable syringe of type specified on pump
- Latex free construction
- Basic functions:
- Purge function
- Bolus infusion
- Pressure level
- Rate titration
- Clear volume
- Rate lock
- 24 hour log
- Set VTBI over time
- Model no. AlarisGH
- Max. infusion rate: 0.1 - 1200 ml/h
- Max. bolus rate: 10 - 1200 ml/h
- Critical volume: 0.5 ml with a 50 ml syringe
- Purge specifications: Max. rate 100 - 500 ml/h
- Purge volume range: 0.5 - 5 ml
- Volume to be infused: 0.1 - 100 ml
- KVO rate: 0.1 - 2.5 ml/h
- Accuracy: ± 2%
- Battery type: Rechargeable sealed NiMH (charges automatically when connected via AC)
- Battery life: > 6 hrs from fully charged at 5 ml/h
- Battery charge time: 2.5 hrs from discharge to 90%
- Occlusion settings: 11 levels from L0 - L10
- AC power requirements: 115 - 230 VAC, 50/60 Hz, 20 VA
- Weight: 2.7 kgs
- Dimensions: 117h x 310w x 200d mm
