The GE HiSpeed Series is designed to meet the needs of radiologists, technologists, administrators, and most of all patients.Ask a New Question4Replies-J4RS20 Wed Jul 14 2021 | Wed Jul 14 2021Scan stops and operator has to restart the equipment to continue Scan stops while doing patient and operator has to completely restart the equipment to continue.
We have the errors 11-10F0-02, 11-1010-02,11-10F2-02Reply |
1Reply-Austin256 Thu Mar 25 2021 | Thu Mar 25 2021CRADLE how do i correct cradle slip error on GE HiSpeed Dual CT scaner
Reply |
1Reply-Beka Fri Feb 01 2019 | Fri Feb 01 2019Service Manual Hello friends, I need your help , I get a following error on GE Hispeed Dual > I am new with GE system , but I have experience with other manufacturers could you please help me with supporting materials ? Like a circuit diagrams , Service manuals and etc Reply |
[list]
[*] Excellent Image Quality
[*] Ease-of Use and Patient Comfort
[*] Responsible Dose Management
[*] Confident Diagnosis with Advanced Applications
[/list]
SERIES MODELS
GE HealthCare - HiSpeed Advantage
| Type (configuration) | Single slice |
| Slices | Single |
| Weight | 2979 kg |
| Maximum Scan Range | 170 cm |
| Gantry (Max. Clearance) | 70 cm |
| Additional Specifications | |
GE HealthCare - HiSpeed CT/e
| Slices | Single |
| Maximum Scan Range | 120 cm |
| Gantry (Max. Clearance) | 65 cm |
| Image Display | 21 in |
| Patient Weight Capacity | 396 lbs |
GE HealthCare - HiSpeed CT/e Dual
| Type (configuration) | Multislice |
| Slices | Dual |
GE HealthCare - HiSpeed CT/i
| Slices | Single |
| Additional Specifications | The HiSpeed CT/i Base System is a Premium Helical Whole Body Computed Tomography Scanner Capable of Routine 1.0 Second Scans. The System Configuration is Designed to Produce Optimum Image Quality, Fully Simultaneous Scan Reconstruction, and Display. The HiSpeed CT/i Incorporates Flexible Utility and Ease of Use Features. |
