Olympus - Soltive SuperPulsed Laser
Surgical Laser
SOLTIVE SuperPulsed Laser is powered by a novel energy source for striking performance compared to conventional Holmium YAG1 Capable of dusting stones in half the time and fragmenting stones relentlessly – with virtually no retropulsion 2. Precisely cutting through soft tissue and state-of-the-art prostate enucleation, with equivalent or visibly improved hemostasis 3 dependent on fiber size.
0Repliesa year ago | Looking for a Service Manual... Does anyone have a service manual for the Olympus Soltive thulium laser system? Equipment: Olympus Soltive Reply |
- Broadest range of settings4 (frequencies up to 2400Hz1, energies as low as 0.025J)
- Designed with modern components, for low cost maintenance
- Cooled with air for quiet operation
- True-to-size 150u and 200u core diameter fibers, for access to hard to reach stones
- Easy “quick-connect” to SOLTIVE™ SuperPulsed laser systems – no twisting or screwing
- Convenient color coding to easily identify fiber types and sizes
Laser Specification | SOLTIVE™ Premium | SOLTIVE™ Pro |
Laser Classification | Class 4 | Class 4 |
Laser Type | Thulium Fiber Laser | Thulium Fiber Laser |
Wavelength | 1920 nm – 1960 nm | 1920 nm – 1960 nm |
Laser Energy | 0.025 J – 6J | 0.025 J – 4J |
Laser Frequency | 1 Hz – 2400 Hz | 1 Hz – 100 Hz |
Average Power | 2 W – 60W adjustable | 2 W – 35W adjustable |
Pulse Duration | 200 μs – 50 ms | 200 μs – 50 ms |
Aiming Beam | Green, 500 – 550 nm, power adjustable 0-5 mW | Green, 500 – 550 nm, power adjustable 0-5 mW |
Product Category | Surgical laser for medical use | Surgical laser for medical use |
Classification of Medical Device Directive | Class IIb | Class IIb |
Electrical requirements | 100-240V~ at 1200VA 50/60 Hz | 100-240V~ at 1200VA 50/60 Hz |
Dimensions HxWxD | 29.5 x 37.0 x 56.0 cm | 25.5 x 37.0 x 56.0 cm |
Weight | 40 kg | 33 kg |
Laser Cooling System | Air | Air |
Protection against electric shock | Class 1 / Type BF | Class 1 / Type BF |
