Midmark - Ritter 411
Procedure Table
The Midmark 411 is the ultimate universal power table because it offers everything physicians need for their medical environment. With its ergonomic design, the Midmark 411 not only looks great… but it comes standard with both a programmable foot and hand control for added convenience. The table can be programmed to four positions, and will move quickly and precisely where the physician wants it… every time.
- Powered positioning of its four functions; back up and down, tilt up and down, foot up and down, and table up and down.
- A hand control, ergonomically designed to fit comfortably in the palm of the operator’s hand, for positioning the table top for an examination or procedure.
- An optional foot control, which allows the operator to position the table for an examination or procedure without breaking the sterile field.
- A manually adjustable head rest which may be adjusted to allow the operator to position the patient’s head in a specific position or orientation.
- A manually adjustable leg rest which may be adjusted into a procto knee rest
- Position for proctologic examinations.
- Right and left stirrups which can be extended to an infinite number of positions as well as laterally in three positions.
- Two 1 in. (2.5 cm) tall x 3/8 in. (0.95 cm) wide accessory rails to allow use of mounted accessories with table.
- A paper roll holder which is hidden in the head end of the upholstered top, and tear strips, located at the foot end and head end of the upholstered top, to secure examination paper during a patient examination or procedure.
- A treatment pan which provides a convenient container to hold or store items or debris for or from an examination or treatment. The treatment pan is not intended to hold more than one ounce (29.6 ml) of fluid.
- Built in diagnostics which allow for quicker and better servicing of the table should a malfunction occur.
- Patient Weight (Maximum): 325 lbs (147.4 kgs) maximum
- Weight of Table: 515 lbs (233.6 kgs)
- Back Section Range: 0° (horizontal) to +85° ± 5°
- Table Top Height Range: 22.5 ± 0.5 in. to 40.0 ± 1.0 in. (55.9 ± 1.3 cm to 101.6 ± 2.5 cm)
- Foot Section Range: 0° (horizontal) to -90° ± 5°
- Table Top Tilt Range: 0° (horizontal) to +30° ± 5° (foot up)
Electrical Requirements
- Electrical: 230 VAC nominal (220 VAC minimum - 240 VAC maximum), 50/60 HZ, 8 amps (Max)
- Paper Rolls: Can accept two standard paper rolls of 18 in. x 3.0 in. (45.7 cm x 7.6 cm)
- Duty Cycle: 15 seconds on / 5 minutes off (motor run time)
- Power Cord: Extends 70 in. (Minimum) from table. 12 AWG / 3 conductor, SJT grey jacketed junior hard service with hospital grade grounding type plug.
