Mobile C-Arm
The GE OEC Brivo Plus provides automated features that can improve your productivity and reduce uncertainty. The Brivo Plus delivers easy-to-use reliable results during each phase of surgery, from boot-up to cleanup. The Brivo easily brings images into sharp focus using intelligent point-and-shoot technology at the lowest reasonably achievable dose. All of the integrated automated features mean less of a learning curve, fewer retakes, and less need to move the patient for better results.
- Fully digital camera.
- High-performance image intensifier.
- 16-bit image processing.
- Premium dual leaf collimator, reducing scatter to a lower dose.
- Great positioning and optional laser aimer for targeting.
- Touchscreen interface.
- 100,00 image storage capacity.
- Membrane-covered keyboard.
- Thumbnail image directory.
Mainframe
- System Height: 67.1" (170.5 cm)
- System Width: 30.7" (78 cm)
- System Length: 70.3" (179 cm)
- Weight: 573 lbs (260 kg)
C-arm
- SID: 39.4" (100 cm)
- Free Space in Arc: 30.7" 78 cm)
- Depth in Arc: 26" (66 cm)
- Orbital Rotation: 120° (90° underscan / 30° overscan)
- Lateral Rotation: 410° (+205° / -12.5°)
- Lateral Height: 40.2" (102 cm)
- Wig / Wag: 20° (+12.5° / - 12.5°)
- Horizontal Travel: 8" (20 cm)
- Vertical Travel: 17.5" (44.5 cm)
Workstation
- Height: 65.7" (167 cm)
- Width: 35.4" (90 cm)
- Depth: 25" (64 cm)
- Weight: 375 lbs (170 kg)
- Monitor Swivel ±90°
- Monitor Tilt Motion: +7° / -10°
