OES Medical - Carina
by OES Medical
Electronic Anesthesia
The OES Carina Anaesthesia Ventilator is an electronic time cycled ventilator with integrated patient alarms for improved patient safety
The Carina ventilator has adjustable inspiratory time, expiratory time and flow rate.
Adjustable low and high pressure alarms are provided, the low pressure alarm is the minimum patient circuit pressure that must be achieved with each breath while the high pressure alarm stops the inspiratory flow when the set high pressure is achieved.
The Carina can be used on paediatrics by changing the bellows unit.
The Carina can be sat on any flat surface or mounted on a dove tail bracket for use on the side of the Astra Anesthesia Unit machine
