OES Medical - Orion
by OES Medical
Anesthesia Pneumatic Ventilator
The OES Orion Anaesthesia Ventilator is a pneumatically driven, time cycled ventilator for use with adults and paediatrics by changing the bellows assembly.
The Orion ventilator has adjustable inspiratory time, expiratory time and flow rate giving a wide range of settings.
For patient safety, the pressure relief is adjustable.
The Orion Ventilator is designed to require minimum servicing and can be serviced without special service tools.
The Orion can be sat on any flat surface or mounted on a dove tail bracket for use on the side of the Astra Anaesthesia Unit machine
Specification
  • Inspiratory Time    0.25 – 3.0 seconds
  • Expiratory Time    0.5 – 6.0 seconds
  • Flow Rate    0.1 – 1.0 litres per second
  • Adjustable Pressure Relief    20 – 80 cm H2O
  • I : E Ratio    derived from inspiratory and expiratory times
  • Tidal Volume    25ml – 1600ml Adult Belows 25ml – 300ml Paediatric Bellows
  • Driving Gas    Oxygen
  • Supply Pressure    45 – 100 PSI (310 – 700 KPA)
  • Airway Pressure Guage    -20 – 100cm H2O Range
  • Gas Consumption    Minute Volume plus 100cc
  • Dimensions H x W x D (mm)    315 x 261 x 255 mm
  • Weight    7 kg
