Carbon Dioxide Absorber
The OES HYDRA carbon dioxide absorber has a unique absorbent canister which is attached to the underside by two toggle clamps for easy removal and replacement, any liquid from breathing circuit condensation is retained in the bottom of the canister preventing contamination and allowing easy disposal.
The absorber has a bypass valve, which allows the canister to be removed in the off mode without loss of fresh gas flow during absorbent replacement.
- The on / off knob and the bag / vent knob are mounted at either end of the absorber with the adjustable pressure relief mounted on the top together with an ergonomic swivelling bag connection arm allowing ease of use.
- The ventilator, fresh gas and exhaust connection are all mounted on the rear of the absorber.
- The complete absorber (excluding the manometer) is autoclavable.
- Absorber on / off knob with canister bypass in the off position for absorbent replacement *
- Quick release manometer –20 to 100 cm H20 *
- Ergonomic swivel bag mount arm
- Patient connections 22 mm male taper with 15 mm female taper
- Ventilator connection 22 mm male taper with 15 mm female taper *
- Fresh gas inlet 1.5 metre hose with 22 mm female taper
- Exhaust taper 30 mm male
- Ventilator / bag selection valve *
| Height | 345 |
| Weight | 7 kg Low specification model |
| Width | 270 Low specification Model |
- Mounting system 25.4 mm (1 inch) diameter hole with clamp screw.
- Absorber leak rate Less than 25 cc fresh gas flow at 30 cm H2O
- Canister capacity 1.4 kg (1600 ml)
- Resistance of the soda lime is 1 cm H2O (0.1 kPa) at 60 litres per minute.
