Sysmex - XN 550
by Sysmex
Hematology Analyzer
Automated compact 6-part differential haematology analyser. With the XN-450 you can run single samples safely in closed mode. It has a fully integrated IPU (information-processing unit) including an LCD colour touchscreen that makes it easy to operate
FORUMSView All (4)
-Huskerboy48
Mon Mar 16 2026
sysmex xn -550 pwer requirements
what are the power requirements sysmex xn-550? I need specifications.
Equipment: sysmex xn -550
-Manal Elsawi
Wed Dec 04 2024
Error
I have sysmex 550
The machine doesn't respond when startup
It's stuck in startup step
I had sensor broken replace with one else
So plz give me hand
Thanks in advance
Equipment: Hematology analyzer sysmex XN 550
-Manal Elsawi
Sat Nov 30 2024
Troubleshooting
Gives error of Hand L- R motor error
Equipment: Hematology analyzer sysmex XN L 550
  • Compact 6-part differential analyser
  • Throughput of 70 samples per hour
  • Single sample analysis in closed mode
  • Fully integrated IPU including LCD colour touchscreen
  • Only 25 µL aspiration volume in whole blood mode
  • More than just CBC + DIFF – added clinical values available
  • Best-in-class diagnostics tailored to small and mid-sized laboratories
Measurement principles
  • WBC DIFF/RET: Fluorescence Flow Cytometry
  • WBC: Flow Cytometry
  • RBC/PLT: DC Impedance method with hydrodynamic focusing
  • HGB: Cyanide-free SLS method
Data storage capacities
  • Results: 100,000 samples
  • Patient information: 10,000 records
  • Calibration history: 20 times/ module
  • QC files: 99 files including XbarM
  • QC plots: 300 plots / file
Aspiration volume
  • 25 µL in WB / Low WBC mode,
  • 70 µL in PD and BF mode
Analysis parameters
  • Whole Blood
  • WBC, RBC, HGB, HCT, MCV, MCH, MCHC, PLT, RDW-SD, RDW-CV, PDW, MPV, P-LCR, PCT, NEUT#, LYMPH#, MONO#, EO#, BASO#, NEUT%, LYMPH%, MONO%, EO%, BASO%, IG#, IG%
  • With RET (optional)
  • RET#, RET%, IRF, LFR, MFR, HFR, RET-He, PLT-O, IPF#, IPF, RBC-He, Delta-He, HYPO-He, HYPER-He
  • Body Fluids (optional)
  • WBC-BF, RBC-BF, MN#, PMN#, MN%, PMN%, TC-BF#
