NeuroLogica - CereTom
by NeuroLogica
Portable 8-slice CT system
The CereTom is an 8-slice CT scanner that delivers the highest quality Non-Contrast, Angiography, Contrast Perfusion and Xenon Perfusion scans in every conceivable patient location. Its combination of rapid scan time, flexible settings and immediate image viewing, make it an indispensable tool to any clinician needing real time data on critically ill patients.
-Murilo Souza
12 years ago
CereTom in Brazil
How can I buy a CereTom in Brazil?
-Ruffian
14 years ago
Lost Communication
My scanner has lost communication with the imaging station. I have to check the connections on the station and there is a connection with no communication. The scanner is Idle and is continuously "powering up" due to the loss of communication. Is there and easy way to fix or attempt to fix this problem.Reply
8 Slice True CT Scanner [list] [*] Complete self contained lead shielding [*] Onboard 10” LCD touch screen [*] DICOM 3 images compliant with CereTom modality worklist module [*] Integrates with all PACS [*] 1.25,2.5,5.0,10.0mm slice thickness [/list]
Type (configuration)Multislice
Slices8
Maximum Scan Range60 cm
Gantry (Max. Clearance) 32 cm
