BC Group - SA-2006
Safety Analyzers
The BC Biomedical Model SA-2600 is a fully automated microprocessor-based Electrical Safety Analyzer with built in Patient Simulator and Bluetooth technology. The SA-2600 has fully customizable autosequence allowing for a full run-though of testing with limited user interaction. This release comes with a 4.3 inch color touchscreen, compatible with the MyBC Mobile App and allows for a multitude of tests to be performed on a device using the same unit and lead connections. It provides a full Electrical Safety Analyzer, as well as, ECG Simulation with four waveforms with constant QRS duration and six machine performance testing waveforms. There is Patient Lead testing for 10 inputs.
SA-2600 Basic Features:
- Custom and fixed auto sequences
- Micro USB and Bluetooth communications
- Small, lightweight portable analyzer
- Line voltage measurement
- Device under test current measurement
- 200mA earth/ground lead resistance
- Point-to-point testing
- Enclosure/chassis leakage current
- External resistance
- External leakage current
- Source receptacle wiring integrity monitor
- MAP (isolation) function
- Internal ECG simulator
- True RMS readings
- AAMI ES1-1993 or IEC 60601 selectable test loads
- 90 to 264 VAC operation
- Touch controls keys – no knobs
- LED status indicators
- Audible feedback
- Self-test points
- Externally replaceable ground fuse
- 4.3” color touchscreen
- Made in USA
STANDARD ACCESSORIES
- BC20-20110 8 FT CHASSIS TEST LEAD (BLACK)
- BC20-17026 GROUND PIN
- BC20-30107 SOFT CARRYING CASE
- UF-0250-01 REPLACEMENT GROUND LEG FUSE
