Hologic - Omni
Hysteroscope
The Omni hysteroscope is designed to allow you to perform your best work. Its quality and flexibility help you get the most out of your day with an all-in-one scope. The Omni scope gives you confidence by offering rod lenses for quality visualization throughout procedures.
- 3 hysteroscopes in one to see and treat pathology with a single hysteroscope
- Long, 200-mm working length facilitates easier access and treatment for larger patients
- Greater patient comfort with easier insertion and small diameter sheaths
- Omni 4K Video System captures and stores 4K-resolution images with an easy-to-use, customizable, and programmable customer interface.
- Omni Hysteroscope offers three interchangeable sheaths with 0° or 30° options for flexible diagnostic and operative capabilities, complete with 200-mm working length to tailor to the patient and procedure.
- Omni Lok Cervical Seal reduces fluid leakage, helps maintain distention, decreases clean-up time after hysteroscopy, and improves procedural efficiencies in the OR.1-4
