DK Medical - Elmo-T3P
by DK Medical
Mobile X-Ray
ELMO-T3 is a cost-effective mobile X-ray system that guarantees ultimate productivity. Thanks to a light weight and compact design, it enables to easily move in limited space such as intensive care, emergency rooms, and operating rooms.
  • Compact Design and one-touch Breaking System
  • Using Houseline System / Easy Installation
  • Light and Compact Design
  • Mobile X-ray system, ELOMO-T3 has a compact design that enables to take an X-ray Imaging even in a small space. This mobile X-ray is useful for patients who are not available to move. It can be operated from any standard wall outlet
  • High Frequency Generator
  • Stable output by the high frequency inverter generator system.
  •  5.1kW maximum current 100mA
  • Smooth Maneuvering
  • Compact and lightweight design to archieve easy maneuverability and good visibility.
X-ray Generator
  • Tube Voltage Range    40 – 110kV (1kV steps)
  • mAs range    0.32 – 100mAs(26steps)
  • Rating    100mA/40 – 50kV
  • Control Method    Inverter Method
  • Power    5.1kW
X-ray Tube
  • Max. Anode heat capacity    42.8kHU(30kJ)
  • X-ray tube focal spot size    1.8mm
  • Target angle    15Ú
Main Body
  • Focus height    455-1,855mm
  • Arm length    1,100mm
  • Column rotation    ±90Ú
  • Total width    586mm
  • Total length    806mm
  • Total weight    145kg
  • Power    Single-phase, Voltage 220V
