Quanta System - Q-Plus C Evo
Aesthetic Laser
With the Q-Plus – EVO Series, practices can customize Q-switch laser configurations with multiple wavelengths, including Quanta’s Ruby laser, the fastest Ruby laser on the market today. The Q-Plus C also features all the benefits of the broader EVO Series lasers — OptiBeam II technology, large spot sizes, fast start up and treatment times, and pre-set parameters. With the option to add a chilled IPL and erbium handpiece, practices can perform hair removal and tattoo removal as well as treat wrinkles, fine lines, pigmented lesions, vascular lesions, and acne scars.
0Repliesa year ago | Need parts for a quanta Hello, needed some advice on where I an fix a quanta Q + C laser tattoo removal machine. Where can one get used parts? need a heat exchanger, flow switches, etc. Service providers recommended? Equipment: Quanta Q+C Reply |
Applications :
- Benign Vascular Lesions
- Benign Pigmented Lesions
- Wrinkle Treatments
- Permanent Hair Reduction
- Tattoo Removal
- Acne Scars
Q-Switch Effect
- A photoacoustic effect targets ink and pigment with no thermal interaction, thus leaving the surrounding skin preserved. These fragmented particles are then removed via the phagocytosis process.
Optibeam II Technology
- This patented handpiece design provides homogenous high-peak power to optimize efficacy, safety and healing time. The Optibeam II handpieces can generate different flat-top spot shapes at various sizes. The round and square handpieces are indicated for benign pigmented lesions, tattoo removal and wrinkles treatments.
More Wavelengths, More Options
- With three true-laser wavelengths (532nm, 694nm, 1064nm) and multiple pulse emission modes, few devices offer the versatility of the Q-Plus EVO. Treat the largest array of tattoo ink colors, including red, yellow, purple, green and blues, even the notorious tough-to-treat light blue, without the cost of disposables or consumables.
Expandability
- Expand your Quanta Q Plus C Laser system with Twain IPL* and/or Er:YAG 2940 handpieces for additional treatment options. The Twain IPL is indicated for permanent hair reduction, dermatological vascular lesions, benign pigmented lesions and Inflammatory acne. Twain 2940 is indicated for skin resurfacing, wrinkles, epidermal nevi, actinis chelitis, keloids, verrucae, skin tags, keratoses, and scar revision, including acne scars.
