Philips - Brilliance iCT
by Philips
Scalable CT scanner platform available in 128- and 256-slice configurations .
Philips Brilliance iCT provides a combination of intelligent speed power, coverage and dose management features. Brilliance iCT is the system that provides you with a quick path to new discoveries in clinical science. The unique mix of technology and patient focused features provides the foundation to support the diverse imaging needs from the most advanced academic institutions to community hospitals and diagnostic imaging centers. Patient-specific acquisition protocols balance image quality and dose utility in the most diverse and challenging patients including those with high Body Mass Index (BMI) and high heart rates. The system delivers low dose protocols that allow up to 80% less radiation dose and 35% lower injected contrast volumes. This provides you greater diagnostic confidence through the elimination of image-degrading scatter.
FORUMSView All (7)
-Sejrej
2 years ago
Tube to hot error
We seem to get this tube too hot error all the time even when we havent been abusing the scanner all day. It almost always happens when we are doing a head neck chest abd/pelvis on one patient. I have also gotten it when we are doing multiple scans of the abdomen such as a eurogram or mesentaric. Now usually the patient is in the 280lb+ range but nit always. I have been told this is a software issue but sfter 6 years there has been no fix. Does any body have idea how to fix. Right now we just lower tbe care does up the kvp and basicly make the images look bad. It seems to be certain protocols so is there a diferent way to build them?
Equipment: Phillips brilliance 128 slice
-ZiggyGT
4 years ago
Reconstruction Hardware Photos Needed
I am trying to locate high resolution photos of the reconstruction hardware for a ICT-SP. I am trying to determine is this Brilliance CT 3DBP card is compatible. 4535-670-56141 3DBP Reply
-Willyking
5 years ago
Xray preparation fail
Hi my friend I have trouble in 256 iCT Brillinace. During xray preparation period the system stoped and shows an error. My inspection: 1- on the DC-DC converter box The (Converter ON Ack) led Go ON for about 1 sec. When boosting 750 vdc Then it go OFF 2- On the ACCU board the (Led 6 C_ON) led Has the same behaverReply
SERVICE COMPANIESView All CT Scanner Companies
[list] [*] iMRC X-ray tube [*] NanoPanel 3D spherical detectors [*] ClearRay collimation [*] Eclipse DoseRight Collimator [*] AirGlide gantry rotation [*] iDose iterative reconstruction technique [/list]
Type (configuration)Multislice
Slices128-256
Maximum Scan Range175 cm
Gantry (Max. Clearance) 70 cm
Patient Weight Capacity450 lbs standard (650 optional)
