Konica Minolta - Sonimage MX1 Platinum
by Konica Minolta
Ultrasound Systems
Introducing the next-generation, compact point-of-care ultrasound system, the SONIMAGE® MX1 Platinum Ultrasound System, with detail resolution for superior image quality. Clinicians can hand-carry the system to the bedside, in an exam room or surgery suite with a new extended battery life that enables a continuous 2-hour scan time. The system leverages an advanced imaging algorithm that achieves improved resolution of ultrasound images while maintaining optimum frame rates. The algorithm improves image quality of color and gray scale modes, delivering speckle reduction and applying a smoothing effect to reduce graininess in the image, helping clinicians make better informed diagnoses and facilitate accurate interventions.
0RepliesTue Sep 10 2024 | No connection to Wifi after Reboot After setting up wifi connection in windows side, unit connects fine to wireless network. Upon reboot (which must be done to leave maintenance mode) unit shows no connection to wifi. I then must go into maintenance mode again and it connects fine. How do i get wifi to connect after setting it up on the back end windows side.? Reply |
