Philips - Brilliance 40
Breakthrough CT performanceThe Brilliance CT 40-channel configuration gives you the speed and detail for the advanced multislice CT studies demanded by top institutions. The breakthrough system opens a realm of possibilities in organ perfusion studies, coronary artery imaging, pulmonary imaging, and critical care. The strength of Brilliance CT is its ability to help you perform comprehensive organ assessment within seconds and with a high degree of fidelity. The Brilliance CT 40-channel configuration features Philips-exclusive Back Illuminated Photo (BIP) technology, which solves the “wire mess” barrier that halted the development of scanners with more than 32 slices.
1Reply3 months ago | Bringing the gantry to zero tilt position . How can I bringing the gantry to zero tilt position with the power disconnected? Equipment: Philips - Brilliance 40 CT Reply |
6Replies6 years ago | Service Manual Hello, Im in searching for a copy of the service manual to the Brilliance 40Reply |
[list] [*] Ultra-fast scan times of 0.4 second full gantry rotation in 40-slice mode operation [*] Best-in-class coverage of 40 mm and up to 40 ips reconstruction speeds using full 3-D cone beam reconstruction [*] Additional detail to enhance diagnosis [*] Extended z-axis coverage capabilities that position CT as a modality of choice in stroke [*] evaluations [*] Philips DoseWise approach for optimal dose efficiency to help protect your patients without compromising image quality [*] Fast data acquisition to streamline departmental workflow [*] CT user environment developed especially for multislice CT [*] Comprehensive support for you in every season of system ownership [/list]
Type (configuration) | Multislice |
Maximum Scan Range | 162 cm |
Gantry (Max. Clearance) | 70 cm |
Image Display | 18 in flat LCD 2 |
Patient Weight Capacity | 449 lbs |
Configuration: 40 mm coverage 40 x 0.625 mm, 32 x 1.25 mm, 16 x 2.5 mm 8.0 MHU MRC X-ray tube Up to 20 images per second RapidView reconstruction 60kW Generator 0.5 sec rotation (0.4 sec optional) Brilliance Workspace
