Medical Printers/Imagers
The P-95DW is a high quality, quick and compact digital monochrome printer with worldwide compatibility for medical applications. User-friendly controls with simple, analog-like operation are conveniently located on the front panel so there is no need to open the printer driver. The printer even includes a rotary knob that enables precision adjustments for brightness, contrast, and sharpness. The compact and lightweight P-95DW incorporates internal 16-bit ASIC image processing which simultaneously achieves superior image quality with faster speed. A high density 325 dpi thermal head and resolution of 1280 x 1280 pixels results in exceptionally sharp reproduction of even the most intricate details.
- High speed printing
- High-density 325 dpi thermal head
- Enhanced user-friendly controls conveniently located on front panel
- Streamlined design with small footprint
- Jam-free reliability
- USB 2.0 interface
- Worldwide compatibility
- Internal 16-bit ASIC image processing simultaneously achieves faster and high quality printing
- Paper save mode allows for more standard prints per roll
- Long lasting quality and reliability
- General Specifications
- Print Method: Thermal printing on thermal sensitive paper
- Dot Density: 1280 dots/100 m (325 dpi)
- Resolution: Standard - 1280 x 960
- Grayscale: 256 levels
- Interface: USB 2.0
- Print Capacity: Up to 254 set at (1280 x 960) page size
- Print Speed: Standard – 1.9 sec.
- Picture Size: Standard – 3.94 x 2.95” (100 x 75 mm)
- Power Supply: 100-240V AC, 50/60Hz
- Power Consumption: 1.5 to 0.8 amps
- Operating Temperature: 5°C-40°C
- Dimensions (W x D x H): Approx. 6.07 x 9.45 x 3.33” (154 x 240 x 84.5 mm)
- Weight: Approx. 5.72 lbs. (2.6 kg.)
- Regulatory Approvals: UL60601-1; CAN.CSA C22.2 No.601-1(C-UL); FCC-Part 15 Class A, ICES-003 Class A; TÜV GS, TÜB GM; CE Mark (EMC 2004/108/EC); MIC approved
