Philips - Brilliance 16
by Philips
Outstanding performance is routine
The Brilliance CT 16-slice configuration is a complete, high-performance system ideally suited to routine CT studies, CTA, and advanced motion-sensitive applications such as CT colonography and pulmonary studies. With fast reconstruction and a range of automated tools to set up patients and manage scans, Brilliance CT 16-slice can help you make the most of each day. The system also includes a range of thoughtful features to help maximize dose efficiency.
FORUMSView All (24)
-MRN031
5 months ago
Serious problem
Hello
When I took a picture of the patient, the ct box suddenly turned off and the log page keeps showing the error S_RTDH_HC_TIMEOUT_ERROR and the ct box won't turn on again
Can you help me?
-Mutuku GK
8 months ago
My Gantry doesn't come on after switching on with the CT box key.
My Gantry doesn't come on after switching on with the  CT box on key. Even after checking all E'stop  buttons and ensuring that they are ok.... It doesn't prompt or come up.... Everything else appears normal
Equipment: philips Brilliance 16 CT Scanner
-Germni
2 years ago
Instalation manual
Hi some body have a install manual for philips ct brillance 16 Thanks
Equipment: Philips brillance 16
SERVICE COMPANIESView All CT Scanner Companies
[list] [*] High-quality imaging, fast reconstruction, task automation, and evolved ways to minimize radiation dose [*] Scan times of 0.4 sec* full gantry rotation, temporal resolution as low as 53 msec, and reconstruction rates of up to 20 ips* [*] Rate Responsive* technology for advanced cardiac imaging, including calcium scoring, as well as retrospective and prospective gating [*] Patented MRC X-ray tube to provide necessary heat capacity for longer scan times, enabling thin-slice imaging [*] Spiral Auto Start*, which allows you to monitor contrast injections and initiate and stop scans without having to leave the scan room [*] Philips DoseWise approach for optimal dose efficiency to help protect your patients without compromising image quality [*] The only CT user environment developed especially for multislice CT [*] Comprehensive support for you in every season of system ownership [/list]
Type (configuration)Multislice
Slices16
Maximum Scan Range175 cm
Gantry (Max. Clearance) 70 cm
Image Display18 in flat LCD 4
Patient Weight Capacity450 lbs
Configuration: 8.0 MHU MRC X-ray tube 60 kW Generator 0.5 sec Rotation (0.4 sec optional) 16 x 0.75mm, 16 x 1.5mm, 8 x 3mm, 4 x 4.5mm, 2 x 0.6mm 6 ips standard reconstruction (20 ips optional) 24 Lp/cm resolution Brilliance Workspace
