Surgical Laser
WaveFront Optimization: Customized treatment based on the unique characteristics of your eye. Larger Treatable Area, Active Eye Tracker, Larger Treatable Area, Perfect Pulse Technology and much more.
- WaveFront Optimization: Customized treatment based on the unique characteristics of your eye.
- Larger Treatable Area: The treatment affects a larger area of the eye than most lasers to reduce common side effects such as halos.
- Perfect Pulse Technology: Small laser pulses are applied in rapid succession to reshape the cornea while maintaining natural (or close to natural) curvature and a smooth surface to the cornea (thus avoiding spherical distortions). A Closed Loop Energy Control system regulates the intensity of the laser beam throughout the surgery and ensures depth errors of less than 1.5 microns. Pulses are offset so overlaps occur one in every five times, markedly decreasing thermal effects on your eye.
- Active Eye Tracker (a component of PerfectPulse): Synchronously tracks the Allegretto Wave in real time during the procedure to ensure the highest possible accuracy. An automatic centering feature facilitates centered ablations and a the Closed Loop Tracking mode double checks the location of the eye before each pulse of the laser. In cases of abberrant eye movement, the active eye tracker responds in less than 8ms.
