Agilent Technologies - Seahorse XF HS Mini
by Agilent Technologies
XF Analyzer
The Agilent Seahorse XF HS Mini Analyzer is a high-performance metabolic analysis system designed to measure key indicators of cellular energy metabolism in live cells. This cutting-edge analyzer quantifies the oxygen consumption rate (OCR), proton efflux rate (PER) (also known as extracellular acidification rate (ECAR)), and ATP production rates in an eight-well miniplate format.
These real-time metabolic measurements are critical for assessing mitochondrial health, cellular function, and toxicity, providing essential insights into bioenergetics and metabolic dysfunction in both cultured cells and ex vivo samples. By offering a comprehensive, systems-level view of cellular metabolism, the Seahorse XF HS Mini Analyzer empowers biomedical researchers and engineers to drive advancements in drug discovery, disease modeling, and metabolic research.
Enhance your mitochondrial and metabolic research with the Agilent Seahorse XF HS Mini Analyzer—a trusted solution for high-precision, real-time cellular bioenergetics analysis. (Generated by AI)
  • Live cell, real-time analysis of cellular energy metabolism platform in eight-well format
  • Multiple parameters reported from each assay well, including OCR, PER or ECAR, and ATP product rates
  • Excellent OCR precision at low rates, providing confidence when working with quiescent cell types, such as naïve T cells
  • High sensitivity that requires 3x fewer cells to achieve robust response, most suited for studies with limited biological materials when working together with XF HS miniplates
  • Four-port injection system with automated mixing feature for assessing immediate cellular responses to substrates, inhibitors, and other compounds in real time
  • Wide operation environment temperature of 4 to 30 °C, allowing the analyzer to maintain internal assay temperature of 16 to 42 °C
  • Web-based analytics tool, Seahorse Analytics, for streamlined data analysis
Controller Description
  • Integrated computer/monitor Windows 10 (64 bit) OS and touch screen interface for full instrument control, basic assay design, and data viewing
Dimensions (WxDxH)
  • 30 cm x 58 cm x 43 cm
Operating Environment Relative Humidity
  • 20-70 %
Operating Environment Temperature
  • 4 - 30 °C
Power Requirements
  • 100-240 VAC, 6 A, 50/60 Hz
Sample Requirements
  • 1500 - 250000 cells/well
