Philips - Brilliance 6
Your entry into the Brilliance multislice CT realm, providing you with remarkable value for excellent routine imaging day to day.The Brilliance CT 6-slice configuration meets routine imaging needs with fast acquisition and high-quality image results, while giving you the room to grow to meet more patient needs in the future.
FORUMSView All (7)
2Replies3 years ago | Protocols Hi I have a problem with my protocols configuration. I try to make change in the protocols and save as for a copy but the system do not save anything.Reply |
1Reply4 years ago | Error : Gantry not started Hi, can anyone help me to understand these errors. i have access to visa key, so can run service tools if required S_COLLISION_BAD_DTH_PARAM S_COMMAND_INVALID_CHECKSUM_ERROR S_DMC_SHOT_COMM_COLLAPSE S_DTH_UNKNOWN_USER S_DTH_USER_ALREADY_REGISTERED S_GAFSTARTUPTASK_DTH_BAD_PARAM S_MASTER_SEQUENCER_GDC_LOW_AFTER_TIMEOUT S_PANEL_DIDNOT_RESPOND_ERROR S_RMC_DTH_BAD_PARAM S_RMC_ERROR_MCO S_RMC_MP_DTH_BAD_PARAM S_RMC_SB_FAULT S_ROTOR_DTH_BAD_PARAM Reply |
2Replies4 years ago | I have a problem with Philips - Brilliance 6 - shoots once and stops and in the majority of cases it does not shot. Hi all, i am a Doctor working in the war zone of Idlib. we dont have any biomedical engineers here to help us, so it is us medics trying to repair devices. Right now we are having problems with one of the only CT scanners we have working here. it is not warming up and the device is giving the following errrors in the log. can anyone help. S_COLLISION_BAD_DTH_PARAM S_DTH_UNKNOWN_USER - S_GAFSTARTUPTASK_DTH_BAD_PARAM - S_MASTER_SEQUENCER_EXIT_STATE_ERR - S_MASTER_SEQUENCER_NO_XRAY - S_RHOST_HVG_HSS_GENERATOR_NON_ARC_FAULT - S_RMC_DTH_BAD_PARAM S_RMC_MP_DTH_BAD_PARAM S_RMC_SB_FAULT - S_ROTOR_DTH_BAD_PARAM - Reply |
SERVICE COMPANIESView All CT Scanner Companies
[list] [*] Advanced performance of your routine imaging needs with fast acquisition and high-quality image results [*] Enhanced diagnosis of small lesions with submillimeter slices [*] Scalable platform for growth and future applications, making it a secure, long-term investment [*] Philips DoseWise approach for optimal dose efficiency to help protect your patients without compromising image quality [*] Fast data acquisition to streamline departmental workflow [*] CT user environment developed especially for multislice CT [*] Comprehensive support for you in every season of system ownership [/list]
Type (configuration) | Multislice |
Maximum Scan Range | 162 cm |
Gantry (Max. Clearance) | 70 cm |
Image Display | 18 in flat LCD 2 |
Patient Weight Capacity | 449 lbs |
Configuration: 5.0 MHU MRC X-ray tube 48kW Generator 0.75 sec Rotation (0.5 sec optional) 6x0.75mm, 6x1.5mm, 6x3mm, 4x4.5mm, 4x6mm, 2x0.6mm 6 images per second reconstruction Brilliance Workspace
FDA AlertsView All
Class 2 Recall: Vertical Brake Hubs of the Computed Tomography...
Philips Medical Systems has decided to recall the patient support vertical brake hub in all its Brilliance systems due to the collapse in the vertical direction. The short key connecting the vertical brake hub to the motor shaft can
