Spectrometer
The Agilent Cary Eclipse fluorescence spectrometer is sensitive, accurate, and flexible. Ideal for use as a routine fluorometer, the Cary Eclipse can easily be switched between fluorescence, phosphorescence, chemiluminescence, and bioluminescence measurements. Additional flexibility can be achieved through various accessories, including temperature control and solid sample handling, automatic polarizers, and a microplate reader for high sample throughput.
The Cary Eclipse fluorescence spectrometer is ideal for fluorescent measurements in life sciences and biotechnology, with high sensitivity and inherent bleaching protection for photosensitive samples. Fast data collection enables kinetics measurements, while fiber optics allow for remote sample measurements.
- Flexible fluorescence spectrometer with multiple data collection modes including fluorescence, phosphorescence, chemiluminescence, bioluminescence, and time resolved phosphorescence.
- Robust and reliable performance, backed up by a 10-year lamp life guarantee (for new Cary Eclipse fluorescence spectrometer systems purchased from Agilent or participating partners).
- Low cost-of-ownership due to the guaranteed long lifetime of the Cary Eclipse fluorometer lamp. This also eliminates the need for lamp replacements, a time-consuming and hazardous waste-producing technical operation.
- Easy-to-use Cary WinFLR software suitable for novice and expert users alike. Easily switch between measurement modes without touching the hardware, and quickly get reliable, accurate results.
- Room light immunity provided by the unique design of the Cary Eclipse fluorescence spectrometer allows the instrument to operate with the front and top panels removed—for easy access to samples and fast installation of large accessories, expanding analytical capabilities.
- Performance and sensitivity that you need right across the fluorescence spectrum due to high-sensitivity optics and detectors.
- High throughput laboratories and fast kinetics applications are well suited to the Cary Eclipse fluorometer, as its xenon flash lamp allows the instrument to capture a data point every 12.5 ms, and scan at 24,000 nm/min without peak shifts.
- Sampling flexibility enables a wide range of fluorescence applications, with accessories available for every sample type—liquids, solids, and powders. Polarizers and temperature control are also available.
- Inherent protection from photodegradation, as the Cary Eclipse fluorometer only illuminates the sample when data is actually being acquired. This protects your valuable samples so you can measure them repeatedly and get the same, reliable results.
Depth
Light Source
- Xenon flash lamp (80 Hz) with 10-year warranty on new instruments
Modes of Operation
- Fluorescence
- Phosphorescence
- Chemiluminescence
- Bioluminescence
- Time resolved phosphorescence
Wavelength Accuracy
Weight
Width
