Dexta - EXTO Chair
by Dexta
Power
The EXTO chair was designed to fill the growing need of doctors for a safe and stable Lasik surgery platform – with easy patient access and exit.
The EXTO chair is the first chair that enables the physician to blend the Femto and Excimer lasers together – into one smooth operation.
Dexta has always been the leader in patient positioning and the EXTO chair is no exception. The EXTO doesn't require a patient to climb to sit, to lift their feet or scoot into position.
Chair Features
  • ETL/CE Certified
  • Electric back and toe articulation
  • Electric vertical lift base (z axis)
  • Electric right and left travel (x axis)
  • Electric for and aft travel (y axis)
  • Extendable headrest with lock
  • Swivel system (several options available)
  • Hand control for entry/exit movement
  • Joystick for precision xyz movement
  • Choice of upholstery color
Safety Features
  • Locked center position enables the hand control, which is used to move the patient forward and backwards on the chair. The joystick is locked out.
  • When the chair is unlocked a warning buzzer sounds. When the chair is relocked the warning buzzer stops.
  • A left and right locked position under the lasers enables the joystick. The hand control is locked out.
XYZ Joystick Features
  • Provides 3 axis variable speed control
  • Jog function movement 1/3000" (.076 mm)
  • X axis travel 4" (102 mm)
  • Y axis travel 8" (203 mm)
  • Z axis travel 4" (102mm)
