Philips - Brilliance Big Bore Radiology
by Philips
An 85 cm large bore and the Brilliance platform
Continuing its focus on clinical imaging innovation, Philips introduces a CT scanner with a larger bore and expanded field of view for radiology applications. The Brilliance CT Big Bore Radiology configuration incorporates the 85 cm large bore and 60 cm true scan field-of-view, makingthis configuration ideal for interventional studies, the emergency room, interventional studies, and bariatric / general radiology imaging where access, speed, and throughput are especially critical.
-Ary Roma
11 years ago
detector
how many of the highest detector CT at Philips
SERVICE COMPANIESView All CT Scanner Companies
[list] [*] 85 cm bore [*] 60 cm true scan field of view [*] Sub second imaging [*] 24 mm of volumetric coverage [*] 650 pound patient support [/list]
Type (configuration)Multislice
Slices16
Gantry (Max. Clearance) 85 cm
Patient Weight Capacity650 lbs
X-ray system • MRC X-ray tube with maximum heat anode storage of 8.0 MHU • Dynamic focal spot • 60kW generator system Data acquisition system • 24 mm volumetric coverage Patient support • 650 lb. (295 kg.) table capacity with full Z accuracy Dose management • DoseRight ACS (Automatic Current Selection) • DoseRight DOM (Dynamic Dose Modulation) • DoseRight ECG-gated dose modulation Scan specifications • True 60 cm scan field of view • 16 x 0.75 isotropic imaging • Sub second rotation time: 0.44, 0.5, 0.75, 1.0, 1.5, 2.0 secs • Sub-millimeter slice width 0.60mm • RapidView reconstruction • Recon matrix up to 5122, 7682 and 10242 • True 3-D cone beam reconstruction Image specifications • Spatial resolution: 15 Lp/cm maximum at 0% MTF (axial and spiral) • Low contrast 4mm at 0.3% measured on 20cm CATPHAN phantom
