Lutronic - DermaV
by Lutronic
Aesthetic Laser
DermaV is the Ultimate Dermatology Platform. Lutronic has solved the equation that has eluded other laser companies for years: take the best wavelength and deliver it at optimal fluence and the correct pulse width. Couple that with the best available skin cooling, and unwanted vascular and pigmented lesions don’t stand a chance.
  • The Best Wavelengths: 1064nm in addition to 532nm, which has the ability to treat brown and red simultaneously with better absorption than other “vascular” wavelengths.
  • Optimal Fluence: a high enough fluence to deliver the necessary thermal energy for best possible results, as well as the ability to lower energy to treat small vessels safely.
  • Variable Sequential Pulsing: The first and only 532nm device to offer ICD cooling and flexible, user-specified Variable Sequential Pulsing, replacing ALL pulsed dye and solid-state green lasers.
  • Effective Cooling: DermaV’s effective & adjustable cooling system (pre, delay, and post) protects the skin & optimizes clinical outcomes.
