Vital Signs/Multi-parameter
The Philips IntelliVue X3 is a compact, dual-purpose, transport patient monitor featuring intuitive smartphone-style operation and offering a scalable set of clinical measurements.
Easy to use
- The IntelliVue X3 is as simple to operate as your smartphone. Just swipe the display to browse through a broad selection of screens tailored to various clinical situations. Each screen can be customized to present exactly what you want to see, the way you want to see it
Designed to improve efficiency
- IntelliVue X3 helps to streamline workflow and boost efficiency by reducing the number of steps to prepare patients for transport. Connected to an IntelliVue bedside monitor, it acts as a multi-measurement module. And once you detach from the host monitor, the X3 turns into a robust transport monitor, with no need to change patient cables before or after transport.
A proven interface
- An intuitive user interface builds on Philips market-leading IntelliVue patient monitors which have been validated and continually improved over 15 years.
See the big picture
- No matter where you are in hospital, it’s important to see your patient’s vital signs at a glance. To view IntelliVue X3 measurements on a standard, high-resolution large display, simply connect the X3 to an IntelliVue XDS remote display.
